Xantia wiring inside ECU box help needed
ekaftan
Donor 2023
Lexia Available: Yes
My Cars: 2006 C5 II Exclusive V6
1996 Volvo 940
x 5
Post by ekaftan »
andmcit wrote:I guess so in my experience BUT getting one with a code is more of a
challenge as many are locked out and don't require a code input... :D
One thing to bear in mind is auto Xantia 2.0i's aren't a widely sold car in the
UK with the majority being diesel or 1.8 petrols. I actually bought a complete
running and MOT'd 2.0 VSX manual for the same value of an ECU earlier in
the year mind! What other parts do you need?
Andrew
A no code would be ok too, as long as it starts the car... I am biding for one in ebay right now from a peugeot.
The ECU should be the same as a manual one, I think...
Parts:
-Marelli ECU
-Hydractive ECU
-Wiring from both ECUs
-Hose from air filter to grille (its missing)
-Microturbine (interior temp sensor)
-Maybe a couple of electrovalves (rear one should be shot by now)
-I also need one of the plastinc round handles from a seat back adjustment.
Thanks !
Mandrake
My Cars:
x 666
Post by Mandrake »
Before getting too carried away with looking for replacement ECU's, why not remove the bodged extra wires (take note of where they were though) and see what happens ?
The first step to fixing any original fault that might be there (assuming there was an original fault!) is removing the previous persons bodging attempts!! There definately should not be linking wires attached to either of those two white wires! (Or any others for that matter)
Regards,
Simon
Simon
1977 G Special 1129cc LHD
1978 CX 2400
1997 Xantia S1 2.0i Auto VSX
ekaftan
Donor 2023
1996 Volvo 940
x 5
Post by ekaftan »
Mandrake wrote:Before getting too carried away with looking for replacement ECU's, why not remove the bodged extra wires (take note of where they were though) and see what happens ?
Update: I did just as you suggested and fixed the wiring. I removed two wires: one jumped the tachimetric relay output (ie, positive when engine runs and a small 12 volt yolt on key to run) with one of the the white wires. The other jumper jumped the two white wire together.
Results: now the car is a stiff as a rock. No suspension movement at all when pushed.
Conclusion: the jumper was there to mask the fact that all 4 corner spheres are completly shot and that the Hydractive ECU is either bad, or detects a fault and does not activate the valves at all.
Car is parked (its undrivable this stiff) until I replace 4 spheres tomorrow.
Next thing to do is try and see it electrovalves measure 4 ohms.
Question: how can I reset the Hydractive ECU? Pull the fuse?
Mandrake
My Cars:
x 666
Post by Mandrake »
Right, so they're supplying 12v when the ignition is on to both electrovalves :x
This will definately overheat them, but if you're lucky they may not have suffered permanent damage from this.
Sounds spot on to me! The hard mode is supposed to be quite stiff, but there is still movement, and the car should be still perfectly drivable stuck in hard mode, it will ride large bumps well but will be fidgety on small bumps.
If it's completely rigid as you say it is, then you'll find it will bounce all over the place like a car with cut springs...
You probably also want to do the test I mentioned previously testing the electrovalves with 12v supplied via a 15 ohm resistor, to confirm the internal diodes are ok.
Also you can use this as a way of testing the hydraulic operation of the electrovalves to see if they both still function ok, even if the computer isn't currently working -
With both the plugs unplugged from the HA2 computer, connect 12v via the 15ohm resistor to pin 1, and ground to pin 8 or 15, then bridge the resistor with a clip lead for a second or so, and you should hear the electrovalve click, when you remove the cliplead the voltage will drop to about 3v which is enough to keep it active without overheating - then try bouncing the car at the front to see if its soft or not.
Do the same with the rear using pin 2. By doing this test you can manually operate the electrovalves to see if they're working.
I'm not sure that it needs reseting, but if there has been bodgy wiring connected etc, then I would certainly remove the fuse for a couple of minutes and put it back, as it does run off direct power, not off ignition switch power...
Regards,
Simon
Simon
1978 CX 2400
Post Reply
