I have a similar problem on our ZX - and think its the ignition switch - which needs replacing when I get round to it. Could be the multiplug which goes through the hearside inner wing but from looking at the wiring diagram that's about all it could be unless its the starter solenoid itself.
Have tested it with a meter - and it worked 100% which is another reason why I haven't replaced the switch. However it worked perfectly after that exercise which suggests the switch contacts had cleaned themselves due to the repeated operation - and the other day I heard the starter soleonoid stutter which suggested to me the switch contacts were sparking and its operation has been a bit intermittent since.
XANTIA 1.9TD INT WONT START ANY IDEAS>?
