9 months / 4000 miles ago I had a total brake failure on my 1997 Citroen ZX 1.4i, apparently due to fluid fade. The offside front got so hot that the disc turned blue and the insulation melted on the pad wear sensor wire. My local authorised Citroen independent diagnosed a faulty OSF caliper causing binding & consequent overheating, and replaced the front calipers, discs and pads both sides, plus offside front flexible hose. (Also rear cylinders and shoes as these were poor.)
The other day I had a loss of braking efficiency and a smell of friction material after coming down a big hill. I'd used a low gear to control speed but still had to brake fairly firmly behind a slow caravan. After parking shortly afterwards, I found that the offside front was very hot, considerably hotter than the nearside. I inspected the brakes next day and found that the offside disc had a continuous band of grey discolouration, over about a quarter of the width of the disc surface. Turning the disc by hand, it was a little stiff most of the way round but freer over say 60-90 degrees. The nearside disc had no discolouration and movement was freer and more even. A friend thought the discs looked slightly glazed. Plenty left on the pads, both sides. The plastic offside pad wear sensor connector block was partly melted away on the side facing the disc. I don't know whether this got replaced when the calipers were done.
The calipers are marked "REMAN", presumably remanufactured. I naively assumed I was getting new calipers, but AFAIR I wasn't explicitly asked or told. They have a Bendix logo and consecutive serial numbers.
I hadn't checked the wheel temperatures before this, but since then I found that after every journey the offside was quite a lot hotter than the nearside.
My main worry is that I once again have an overheating offside front, which previously resulted in a scary brake failure. What might cause the same side to overheat despite having new calipers, discs & pads both sides? There's no temperature difference between the back wheels, which I imagine there might be if the cause was weakness in one circuit? Perhaps it's just co-incidence and I got a dodgy reconditioned offside calliper.
I took it back to the garage today, they say they tried hard to find something wrong but couldn't. They cleaned & lubricated & made sure the calipers were operating freely. Also checked on rolling road. After the 1-mile journey home with only gentle braking, the offside front wheel nuts were uncomfortable to touch for more than 2-3 seconds, whereas the nearside were only starting to become uncomfortable after 8-10 seconds. I think I'll take it for a good old spin, then straight round to the garage and invite them to feel my nuts.
