Changing the thermostat ?
caveman_si
Unread post by caveman_si »
How often do you change the thermostat?? assuming it not broke
I just ask as im doing a coolant change and flush in the next few day and wonder whether its worth getting a new thermostat at the same time. Some preventative maintnance. The current thermostat was changed 2 yrs ago when i did the last coolant change and has been working fine. so i dont have to change it, but just wondering if i should.
cheers si
406 lx 1.9td estate
AndersDK
Unread post by AndersDK »
My bet that most cars never get the thermostat replaced during their useful life.
They are mechanical components that wear - though slowly.
After 10 years most thermostats will no longer close fully - then causing a longer warm up period for the engine - i.e. its slower to get the demister effective during wintertime.
But 2 years should not be a problem. That would be waste unless you have indications of a problem.
Anders (DK) - '90 BX16Image
Candyman
Unread post by Candyman »
I would'nt bother changing it if there is no current problem with your cooling system such as overheating. As they say if it aint broke dont fix it.
caveman_si
Cheers guys
Just thought best that i check about replacing it since its coming out anyway. Guess i'll be saving my money and buying an icecream instead.
406 lx 1.9td estate
joshm
Unread post by joshm »
I just changed mine (as you may see in another thread, it didn't go so smoothly!). It looks like it had never been changed before, and the car is ~15 years old. The chances are that it was still working ok but I wasn't going to take any risks. Like everyone else says, no point unless there is a cooling problem, especially since it was done 2 years ago.
James.UK
Unread post by James.UK »
When I changed mine, some 2-3 years ago. I also changed the rad thermostat-sender and my Radiator cap as my fans rarely ever came on. They cut in much earlier now.. :)
Maybe you would like to consider doing the same next time you change your thermo. All the parts were cheap and easy to swop over.. I used loads of copper grease on the new ones in case there's a 'next time' .. :roll: :lol:
James. (Nr M67 East of Manchester).
Dark Blue ZX 1.9D Auto 1994 'L' 5 dr (modified) Aura. 98K miles used daily. Ave mpg 40
Wedgewood Blue 75 CTD auto Connoissaur. 2002. 144k. used daily. ave mpg 40 ish.
dancingdog777
Unread post by dancingdog777 »
I've just spent 4 hours trying to change the !?!?!? thermostat on my 205 GRD. Wish I'd known about the need to remove that pesky circlip! A previous owner had used a blue adhesive as well as a gasket, and most of that time was taken trying to scrape the old gasket off! In the end I didn't change the thermostat cos I can't get the circlip off, though it needs doing cos the old one has failed, luckily in the open position. Guess I'll get our local visiting mechanic to do it, though I was trying to save money!
droylsden dave
Unread post by droylsden dave »
Ive got a p reg 406 and noticed doing a 45 mile trip at a time,on mway the temp guage is under 80. Around 75. I aint good with cars, but was wondering if this is a little low? But it does go up when around town or stuck in traffic.
Any advice would be appreciated.
dancingdog777
Provided the needle doesn't go too far towards the red section you've no worries. On a hot day, or when towing, it might go a bit further but if it stays out of the red you need't worry. If you think it's getting a bit too close to the red section put the heater on full with the booster motor on full, because the heater acts like a second radiator.
