Xantia Activa alloys, A Question
Post Reply
Stewart(oily)
My Cars: Citroens since 1990, BX Diesel, GTI, TZD with 1.9 TD running extra boost before it was fashionable!, ZX Volcane TD, S2 Xantia break 1.9TD, Xantia HDI 110, currently zipping about in a C2 Diesel. C2 died from the dreaded worm, C3 Picasso HDI Exclusive, the adventure continues.
x 31
Post by Stewart(oily) »
I have recently acquired a set of Activa alloys intending to fit them to my TD Estate, there are no bolts with them and peering down the bolt holes seems to reveal a flat place for a washer to locate the wheel, just like the speedline alloys on my BX rather than a tapering fitment like the standard Xantia bolts, can an Activa owner put me right please?
Stewart
Homer
My Cars: Current:
Volvo V60 D4 180
Previous:
BX16RS (two of),
BX19TZI,
Xantia 2.0i saloon,
Xantia 2.0 Exclusive CT turbo Break,
Peugeot 807 2.0 HDi 110,
Renault Grand Scenic, 2.0 diesel (150bhp)
C5 X7 2.0 HDi 160 which put me off French cars possibly forever
x 16
Post by Homer »
Same with the Exclusive I had, bolts had a flat washer not a taper.
Stewart(oily)
x 31
Sounds right to me, thanks Homer.
Stewart
AndersDK
My Cars:
Post by AndersDK »
http://www.citroen-pr.net/catalogues/il ... 161350.gif
Donno if its exactly one of the styles shown - but the wheelbolt with washer is the correct type :
96.070.416 WHEEL MOUNTING SCREW Dkr46,80
Some £4ea. from your friendly stealer ...
They are 12x1.25 and also fits Peugeots if you want to hunt down cheaper alternatives 8)
Anders (DK) - '90 BX16Image
deian
My Cars:
Post by deian »
I've got washers on my exclusive too
Lexia Available: Yes
My Cars: -
1997 Citroen Xantia V6 (France)
1999 Citroen XM V6 ES9 (France)
2011 Peugeot 308 CC THP 155 (NZ)
1975 Jaguar XJ-S pre-HE (NZ)
x 833
Post by xantia_v6 »
The Mk 1 VSX style alloy wheels also had the flat washers.
Note that cars that were factory fitted with alloy wheels were supplied with a steel spare wheel with inserts so that the bolts with washers could be used, but (at least on my car) the locking bolts wll not fit the spare wheel.
sub42
My Cars:
Post by sub42 »
AndersDK wrote:http://www.citroen-pr.net/catalogues/il ... 161350.gif
Anders! Why can't you do that when I ask about a part? A nice little picture of the left hand front door window regulator, and the clutch cable for my Synergie would be nice!
Previous convictions for ferret and giraffe rustling.
Synergie 1.9td SX loaded spec.
AndersDK
My Cars:
Post by AndersDK »
I must admit that it looks like I dont want to service you like other members here :oops:
But its all up to some practical problems using Citroen's PR-net :
The Synergie model was not sold in DK under that name. Hence the Synergie does not show up in the list of models when I open PR-net.
I donno what the correct model variant name is outside UK :roll:
Besides there are substantial differences on pedal/cabling parts for LHD/RHD variants. And finally the retail prices comes up in Dkr.
I cannot login pretending I'm a UK resident/dealer. Only as a true DK resident/dealer.
Ive got :
Berlingo
Berlingo II VP
Berlingo II UP
C8
C15
C25
Jumpy
Jumper
Jumper II
Jumper III
Evasion
Which one would be a synergie ?
NiSk
My Cars:
Post by NiSk »
Evasion!
//NiSk
'85 BX 16TRS, '91 XM injection 241,000 km (company car), '93 XM TD12 (515,000 km), '98 XM 2.5TD Break (320,000 km)
andmcit
My Cars:
x 30
Post by andmcit »
sub42 wrote:Anders! Why can't you do that when I ask about a part? A nice little picture of the left hand front door window regulator, and the clutch cable for my Synergie would be nice!
http://i59.photobucket.com/albums/g318/ ... clutch.gif
http://i59.photobucket.com/albums/g318/ ... window.gif
8) :wink:
Andrew
sub42
My Cars:
Post by sub42 »
AndersDK wrote:I must admit that it looks like I dont want to service you like other members here :oops:
Ive got :
Berlingo
Berlingo II VP
Berlingo II UP
C8
C15
C25
Jumpy
Jumper
Jumper II
Jumper III
Evasion
Evasion! 1.9td. right hand drive '2000. Thanks Anders. Anyway, I am now looking into the blag that will give me my own username and password :) Again, thanks for your time, much appreciated.
sub42
My Cars:
Post by sub42 »
AAAAAAARRRRRRRRRRRRGGGGGGGHHHHHHH!
I might want to check all other posts first eh? My turn to get embarrased! Thanks Andrew! It's been a four-pack kind-of hot summers evening if you know what I mean. I've actually been smashing the backbox on the bus, trying to stop it from banging on the axle. Local Citroen Express center wanted £250 for a new box!
Thank you all very much :)
andmcit
My Cars:
x 30
Post by andmcit »
xantia_v6 wrote:The Mk 1 VSX style alloy wheels also had the flat washers.
They're the tapered type on my VSX's...
http://i59.photobucket.com/albums/g318/ ... /wheel.gif
xantia_v6 wrote:Note that cars that were factory fitted with alloy wheels were supplied with a steel spare wheel with inserts so that the bolts with washers could be used, but (at least on my car) the locking bolts wll not fit the spare wheel.
Good point that's not normally remembered until an offside front flat on a dark wet November evening on the skiddly narrow hard shoulder of the elevated concrete section of the M5 in Birmingham... :shock:
Andrew
AndersDK
My Cars:
Post by AndersDK »
Andrew -
Appreciate very much you submit the images.
But they are too large in format. There are still quite a few members with slow modem connections for whom its a small nightmare waiting for the images to load.
Could you please either reduce the images or just submit the URL.
You may have noticed I always submit the URL for the same reason.
Thanks.
sub42
My Cars:
Post by sub42 »
Also apologies to Stewart for a minor hijack of his thread..... :roll:
Post Reply
