Hi all, a friend has sold me a two channel BOSS powered amp. Is it ok for me to cut into wires for front speakers and run them through this unit and out of the back, and then onward to the speakers?
Car is a Xantia with standerd stereo.
I guess one side effect is that I will be amplifying the dash tweeters too? aren't they wired in with the front door speakers?
I realise the standard speaker wires are fairly light duty.. I dont know if this will matter, but I reallly dont want to rewire the fronts completely with new cables..
hmmmm.... any thoughts?
John
off subject.. amplifier
becareful if your amp is expecting "line level" from the input,
if you are going to use your car stereo's speaker outs as the input for the amp then you will more than likely damage the amps. you need to see if your new amps accept the high-level input.
line-level(is the term i prefer to use) or low-level(some like to call it) uses a range of 240mV to 6.6 V where as high-level uses some 2 volts to 50 volts! so you may have to get on the look out for something to drop the voltage level.
ZX 1.4I 1993 Reflex KDX
The variable input potentiometer is used to change the sensitivity of the amplifier, usually between 0,7V and 8V (line leve inputs).
To use the amplifier from the speaker connections you need a level converter, that converts High level signals from the radio to low level (or line level) signals to drive the amplifier.
Any car audio shop should get you those units.
Francisco
C5 2.0HDI smoothly riding on 1.8l version spheres
When the hearts beats like a pressure regulator you know it means one thing: Love
Citroën - pacemaking since 1955
