Citroen 'Specialist'
- My Cars: C5 V6 Mk1 assainated by wife
Renault Kangoo 1.6 auto, tarted up and remapped
Still missing the Xantia V6
Not missing the AX - Contact:
Well I look at it this way, if you pay £450 for a belt change and next week the pump springs a leak you'll be in for another £450. I had my pump changed because it was beginning to weep, you might find that when yours is apart it is doing the same as this is a common fault. Your mechanic should advise on what's neccesary when he gets it all apart.
Lexia ponce
Lexia ponce
- demag
- My Cars: "H" Citroen Bx Tgs Automatic.
2006 Toyota Prius T4 Gen 2. - x 102
I think the concensus is to change the pump and tensioner pulleys at the same time for the very reason that Stempy has just stated. I had them all done on the 405 and when checked the pump had a slight weep. But I think the idiot tightened the alternator belt too much because I have a high pitch noise from that area now which I think is alternator bearings.
Dave
When I changed the cambelt on my TD I also changed the auxillary belt and even with the tensioner backed right off it felt ridiculously tight!!!demag wrote: But I think the idiot tightened the alternator belt too much because I have a high pitch noise from that area now which I think is alternator bearings.
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
2001 Xantia 3.0 Exclusive
1999 Xantia 1.9TD
1997 Xantia 3.0 Exclusive
1995 XM 3.0 Exclusive Estate
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
My V6 is in for it's cambelt change today so I'm keeping everything crossed.... They have given me a C3 courtesy car.... quite impressed, never sat in one before, quite a 'jiggly' ride but Isuppose I've been spoilt by Hydropneumatics. Oh yes! Modern Citroen is now called Dryden Citroen and has definately improved it's 'back street garage' image.
http://www.dryden.citroen.co.uk/
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
All done... mine has the later water pump and was advised that it didn't need changing. However, the 'experience' was slightly spoilt by a phone call from the garage saying that both my front and rear brake discs were 'corroded' and did I want them changed........ My rear discs were changed in January, my front discs and pads were changed in April...
Oh well!
Oh well!
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
Apparently it is standard practice 'because it might not come into them again for at least another 12k miles' so they advise changing them 'just in case'.......
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
