Xantia V6 Overheating
- xantia_v6
- Lexia Available: Yes
- My Cars: -
1997 Citroen Xantia V6 (France)
1999 Citroen XM V6 ES9 (France)
2011 Peugeot 308 CC THP 155 (NZ)
1975 Jaguar XJ-S pre-HE (NZ) - x 825
I finally got around to playing with the Bitron on my Mk 1 Xantia V6, and the Bitron is definitely below the LH headlight.Stempy wrote:The Bitron cooling control module on the V6 is in the box with the engine and suspension ecu.
A bit of Servisol sprayed into the connector seems to have cured the intermittant temperature warning light, which had been getting quite frequent. The A/C seems to be blowing colder as well!
There are a couple of beefy relays in the ECU box on the RH side of the engine compartment, what system do they control? one of them looks like it has been overheating, as the plastic case has a bulge in the top.
- My Cars: C5 V6 Mk1 assainated by wife
Renault Kangoo 1.6 auto, tarted up and remapped
Still missing the Xantia V6
Not missing the AX - Contact:
This is purely speculation but they could be the heated seat control units. You could try unplugging them and if the seats dont get warm you have your answer.
Lexia ponce
Lexia ponce
