Just as another comment on this - whether it will help you or not, I don't know lolsteelcityuk wrote:Yes it does. Today going to work the rear suspension bottomed out crossing a junction, I wasn't going fast and the junction isn't bad at all, I've crossed this junction many times in my pug and never had anything like it bottoming out. I've noticed that one of the rear bump stops is in bits, just like a small mis shapen piece of foam. Would this indicate a long term problem?
Thanks.
Steve.
I've just replaced the accumalator sphere on mine, as it was completley flat. This has now stopped the rear end of the car from dropping when pulling away.
Personally, if I was getting all the problems you are getting I'd be tempted to change all the spheres, and hydraflush, refill and bleed the system. That way you know the LHM is good, the spheres are good and there's no air in the system and you can work from there.
Thats what I've done with mine. I bought mine cheap off ebay. All the spheres were flat, and the LHM was mucky so it was doing some slightly strange things. Now with all the above done it's as good as new.
Perhaps something worth thinking about
