Ever since I've had my Xantia I've never been entirely happy with the performance of the front brakes. (compared to two other Xantia's I have access to which have pin sharp brakes, let alone the GS's and CX's etc that I've driven or owned in the past)
I've done all the usual things to them - new good quality pads, lubricated the calipers, bled them, etc, and everything checks out fine, but they just aren't as sensitive as they should be.
To be clear - hard emergency braking is fine, I can easily trigger the ABS and do a respectable crash stop. What isn't fine is light to medium braking.
I've noticed two related symptoms - one is that after a few days of lack of use the sensitivity to light braking gets even worse to the point where you have to press moderately hard to stop the car against the automatic transmition at traffic lights.
If I go for a brisk drive and apply the brakes hard a few times suddenly the sensitivity for light braking returns to about 80-90% of what I would consider normal but the effect always wears off after a few hours. The new pads have been in over 6 months now so I doubt there are still any bedding in issues.
The other thing I notice is that when first driving the car after a couple of days at the same time that the brake sensitivity is poorer, the pedal seems a bit softer than normal, but if I pump the pedal hard a few times it seems to get stiffer and feel more like a normal stiff Citroen brake pedal.
(Yes, it long ago had the "silly spring" removed so the pedal SHOULD feel stiff)
Until recently I was leaning towards it being due to the front discs being slightly curved, (causing incomplete pad contact for light brake pressures) but now another possibility has occured to me - what if one or both of the front brake hoses have perished and are starting to internally collapse ?
This is not an uncommon problem on some cars, although I havn't heard of it on the Xantia before. Could the inside of the hose be partially collapsing at the bends in the hose when the car is resting, causing the hose to have to expand again when pressure is applied ?
(Thus slowing the brake response and losing the sharp edge the brakes should normally have)
Another clue is that when I got the car the hydraulic system had RED oil in it, so without knowing what that oil was, it could potentially be something that could damge the hoses......
Any ideas ? I'm assuming the hoses are relatively easy to replace ? Are they expensive ? If they're not I might just replace them and see what happens as I've basically done every other thing possible to the front brakes short of replacing the discs...
Regards,
Simon
