Cambelt change on 1.9TD
Whatever you do, avoid a franchised dealer. Timing belt kit and water pump cost me £370 two weeks ago on my trusty old 212,000 mile 306TD. Got all the bits back and was interesting to note that the tensioner bearing looked like it could have done another 70,000 despite never having been changed from new.
- Kowalski
- My Cars: Ex 05 C5 2.0 HDI Exclusive 145k
Ex 97 Xantia 1.9TD SX 144k
Ex 94 Xantia Dimension 1.9TD 199k
What if the replacement failed in the next interval?AndersDK wrote:Dear deere -
Thats falsh thinking
What IF -
The tensioner failed during the next belt interval
If the bearings are in good condition and there is no reason to suspect it will fail, why change it?
Parts fail prematurely and parts wear out, statistically speaking if you look at the life cycle of most things, you're better off with nearly new than new
Personally I've just changed my belts and I didn't change the tensioners, I did change the water pump, but changing the water pump was the reason I was changing the belts rather than changing the pump speculatively.
- My Cars: 2010 Citroen C5-X7 tourer
1998 Citroen Saxo 1.5D
2018 Citroen C4-B7
1998 Peugeot 306. 1.9D
2011 Citroen C1 - x 72
- Contact:
I agree with Kowalski on this. If as Gammy said, his engine has only done 60,000 in 6 years, there's no way the tensioners would need replacing. I've had XUD's in BX's and 205's and Xantias and although I've changed belts at 45K, I've never needed to replace tension pulleys before 120K.
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
