my first gremlin :(
Post Reply
jgra1
(Donor 2021)
My Cars: 2010 C5 X7 2.0 hdi 160 exc auto
MG TF 135
Boxer II 2.2 camper conversion
BMW R1200RT
BMW K1300 R
Honda V F R 800 5thG / MT500 Armstrong
x 39
my first gremlin :(
Post by jgra1 »
guys, after 2 days owning my 98 xantia V6 a horrible thing has happened...
in a very residential neighbourhood, my alarm is freely going off :(
the hazard lights are not flashing. I have disconnected the battery tonight, and all is quiet.. but my confiedence is ruined with reference to alarms.. I will be awake any nights the battery is connected, wondering if it will go off...
how can I quickly remove the siren from the system, either permanently or in an emergency?
what is likely to be causing this misguided activation?
thanks
John
f00lzz
My Cars:
Post by f00lzz »
First things first.... lock your car with the key not the remote.... this means that the alarm is not armed.
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
2001 Xantia 3.0 Exclusive
1999 Xantia 1.9TD
1997 Xantia 3.0 Exclusive
1995 XM 3.0 Exclusive Estate
jgra1
(Donor 2021)
MG TF 135
BMW R1200RT
BMW K1300 R
x 39
Post by jgra1 »
ok...
thankyou
what does the button on the dash do, looks like - soundwaves are banned - ? ;)
f00lzz
My Cars:
Post by f00lzz »
So you can lock the dog in the car and he won't set the alarm off ... basically!
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
deian
My Cars:
Post by deian »
but leave a little gap in the window and some water for the dog, and remember dogs die in hot cars. So only do it in the winter. :lol:
AndersDK
My Cars:
Post by AndersDK »
Try a search on ultrasonic sensors. These are reputed to set off the alarm by itself ...
Some Xantia models have a small toggle switch to disrupt these sensors.
Anders (DK) - '90 BX16Image
andmcit
My Cars:
x 30
Post by andmcit »
In my Xantia Handbook mode...
"Switching off the siren.
To neutralise the siren so that it will not sound, open the bonnet, lift the cap off the lock situated below the air inlet grille, introduce and turn the vehicle key. The detection functions will still operate, but the siren will not operate.
Do not forget to neutralise the siren should the vehicle battery be disconnected.
If your vehicle is fitted with deadlocks, the alarm is armed by deadlocking the vehicle with the remote control."
Got that!? :)
Andrew
jgra1
(Donor 2021)
MG TF 135
BMW R1200RT
BMW K1300 R
x 39
Post by jgra1 »
thanks all ;)
Stempy
My Cars: C5 V6 Mk1 assainated by wife
Renault Kangoo 1.6 auto, tarted up and remapped
Still missing the Xantia V6
Not missing the AX
Contact:
Post by Stempy »
Mine has the same trouble, but I'm pretty sure it's the ultrasonics as if you disarm them the siren stays quiet. A bit of a pain to change them so I've left it until I can figure out a way to find out is it's the transmitter or receiver that's duff to save having to change them both.
Lexia ponce
deian
My Cars:
Post by deian »
Alarms are a pain in the back side, mine goes off randomly from time to time to, 4 times in 2 months for what i feel no reason.
I guess it could be down to... wait for it... "anything"!
jgra1
(Donor 2021)
MG TF 135
BMW R1200RT
BMW K1300 R
x 39
Post by jgra1 »
2 things..
when mine went off last night, it didnt activate the flashers, and couldnt be turned off with the button on key (or opening the car or starting it up)
And, if i try to disable the ultrasonic sensors, according to my manual, and tests, it only happens once. i.e i have to disable them every time i leave the car :(
hmmm :?
lawns
My Cars: Xantia 11 2.0 HDI. 110
C3 1.4 HDI DV4C A51
Peugeot 3008 2.0 HDI 150
x 3
Xantia alarn going off randomly when set.
Post by lawns »
Hi all.
I do not know if I have a cure for your alarm going off.
Mine randomly did the same till I replaced the main car battery due to low volts off charge, even though its green indicator said it was O.K
That was two months ago and so far so good.
Xantia HDI 110
mbunting
My Cars:
Post by mbunting »
WARNING:
If it only seems to be when outside the house that the alarm goes off randomly, it may not be false alarms, but someone who is after your car.
They used to do this ages ago - make the alarms go off for a while until the owner gets fedup and disables the alarm - then they'll have either the contents or the car away !
On the other hand, my dad's Xantia used to go off every now and again - we found that by setting the vents to face level, and turning off the face-level vents, it solved the problem !
Mat.
405 STi Auto Est
Cruise, Aircon, Sunroof
Post Reply
