Xantia HDI MPG?
I had about the same mpg when i went to thruxton the other week 500 + miles plenty of stick as wellAlec wrote:I get abot 550-600 miles from a full tank to the reserve light on average about £50 of diesel. Not sure of mpg but seem quite good.
2013 Berlingo Multispace 1.6 XTR 115bhp
2003 2:0 HDI Dispatch Van 186000 miles......gone
2000 Xantia Hdi 90bhp Forte Estate 97000 miles gone..........to heaven
New High pressure Fuel Pump and Patched ECU , Blower Module fixed by CitroJim
- My Cars: 2010 Citroen C5-X7 tourer
1998 Citroen Saxo 1.5D
2018 Citroen C4-B7
1998 Peugeot 306. 1.9D
2011 Citroen C1 - x 72
- Contact:
Kerb weight of C5 Estate 1520Kgs
Kerb weight of Xantia Estate (2.1) 1380Kgs.
I get 450-500 miles from a full tank in my estate. I average 38-40 mpg and had similar from my last Xantia hatch.
I have read that certain fules are more efficient than others. I think it may the Shell and BP (expensive ones) but haven't tried them so don't know if that affects it at all. I use good old supermarket soup. (all of Sainsbury's fuel is supplied by BP anyway!!)
Had (Saxo VTR 1999 (T) LPG converted - do not ask!!!)
Had (Xantia LX TD 1995 (M) 144,000 miles)
Had (Xantia TD Estate (N) 147,000 miles !)
NOW GOT Picasso 2.0HDi (02) 96,000 miles
Its the additives that make the difference.
For example, why do people buy expensive French mineral water rather than supermarket own brand british water? Its just water after all, but one contains more minerals than the other. Its the same with diesel!
Our local Bosch Authorised repairer says that its best to use big brand fuel and an occasional shot of millers doesn't hurt.
Ben
Ben
Come on guys... we all know that they supply fuel to a standard as long as you use the correct standard for your vehicle.... what the hell!!
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
2001 Xantia 3.0 Exclusive
1999 Xantia 1.9TD
1997 Xantia 3.0 Exclusive
1995 XM 3.0 Exclusive Estate
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
I've just filled up my Xantia, 603 Miles on 54 LITRES. 50 mpg. The best i've got to date! Normally get around 45 mpg, seems more dependent on the make of Diesel then how it's driven.
BP Ultimate is the worse (41 mpg), Normal BP, Shell & supermarket diesel average 45mpg, ESSO diesel seems to be the best overall.
It does feel quicker on BP ultimate, but not worth the extra price or drop in economy>
Anybody else found these differences? I've done 4000 Miles since the end of march, so the more mpg the better.
My normal garage is Shell in Wickham out of which I have averaged 45mpg. However, I have changed the oil and added Greased Lighning to the oil (this stuff got me 50 miles per tank more on my old petrol Xantia).
Was going to fill up at the Shell but passed the Sainsburys in Fareham at 95.9p per litre, 1p cheaper than the Shell! so filled up there. I will post the results.
- Kowalski
- My Cars: Ex 05 C5 2.0 HDI Exclusive 145k
Ex 97 Xantia 1.9TD SX 144k
Ex 94 Xantia Dimension 1.9TD 199k
The Greased Lightning sections on QVC really do make me laugh.Garysz wrote:My normal garage is Shell in Wickham out of which I have averaged 45mpg. However, I have changed the oil and added Greased Lighning to the oil (this stuff got me 50 miles per tank more on my old petrol Xantia).
If an oil additive says it can improve your fuel economy by 10% by reducing friction, they're suggesting that AT LEAST 10% of the energy in your fuel is lost to friction in your oil, it is simply not the case.
"Greased Lightning Extended PTFE Oil" contains PTFE, that is how they claim to be reducing friction. I'll quote Dupont, the inventor of PTFE and holder of the Teflon trademark "Teflon is not useful as an ingredient in oil additives or oils used for internal combustion engines."
Have a read of this... http://www.carbibles.com/snakeoil.html
