citroen XM
I am sure you have as much to contribute as anyone else, your a 'hands on' man like myself.
Regards
Peter.
Flat Xantia
- My Cars: Currently:
In the past: 3, CX td Safaris and about 7, XM td estates. Lovely cars. - x 1207
foolzz :
A louder 'knocking' noise can just be indicative of higher compression. Have you used the same thickness head gasket as before? if so, and you had the head machined, you will now have a higher compression ratio. Did you re seat the valves or adjust the clearances? this to could increase the compression
The only way you could have advanced the timing without being a tooth out, is if you have altered the pump position. If it was advanced by one tooth it would make a considerable difference, in fact the engine would be very uncouth - if you could start it!
Thanks for the replies guys.... I had the head reconditioned by a reputable company .... www.motorcast.com they did all the machining, new cam, valves, supplied bolts, gaskets etc. so am confident that they did the job properly. I thought maybe I had got the pump timing out slightly, but your replies virtually dispell that theory, but i'm sure my engine sounds noisier than my brothers 1994 TD
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
2001 Xantia 3.0 Exclusive
1999 Xantia 1.9TD
1997 Xantia 3.0 Exclusive
1995 XM 3.0 Exclusive Estate
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
If you have had the head fully reconditioned the compression probably will be higher which will increase the 'cackle' but it should quieten down when warm. Replacing the injectors will also make it noiser as the injection pressure is higher. A good 'cackle' is generally a sign of a healthy engine, as long as its not excessive.
