TD's and stuck throttles
- fastandfurryous
- Location: On the road, travelling at high speed. Meep Meep.
- x 4
Considering the mess that EGR valves make of intake systems anyway, I would have thought that you could buy a 1.9td laguna II very cheaply, and then just remove the EGR, blanking the ports on the intake and exhaust manifold.
Cheap car, cheap fix, no further problems....
Maybe?
Maybe?
This is not a signature.
- My Cars: Current - Slightly modified 2016 Pug 308 Puretech 130 Allure
Past:
2003 - 206 GLX TU3JP & 206 SE ET3JP4
1995 - 405 Executive XU10J2
1996 - 406 GLX XU10J4R
1994 - 405 GTX XU10J2 - x 1
I doubt that the 1.9 DCi lump would be in a Volvo
Volvo are owned by Ford
I know Ford & PSA got together to do the TDCi lumps & V6 2.7 HDI lump that appears in the Jag & other Ford & PSA cars.
You might find a Nissan with a DCi lump in, Not that anybody in the know would have a new Nissan with its lovely Renault electrics
Renault electrics make Fiats look good
- Kowalski
- My Cars: Ex 05 C5 2.0 HDI Exclusive 145k
Ex 97 Xantia 1.9TD SX 144k
Ex 94 Xantia Dimension 1.9TD 199k
The 1.9Dci was in the old S40 and V40, also in the Mitsubishi Carisma. The Carisma and S40 were a joint venture between Volvo and Mitsubishi, made in Holland in what was the old Daf plant, that plant made the 340 with Renault petrol engines, so their was history between Renault and Volvo.p20 wrote:Where else did the 1.9dci engine go? Is it in the Volvos?
- fastandfurryous
- x 4
Depending on what year S40 and V40 you're referring to, I'm not sure this is completely true, as the 1.9DCi engine is electronic control (high pressure and electronic injectors, HDi style-e) is it not? The "old" S40 and V40 (from 1996-ish onwards) had the mechanical injection 1.9TD Renault engine, similar to that fitted in Clio's, Megan's and R19's etc.Kowalski wrote:The 1.9Dci was in the old S40 and V40,p20 wrote:Where else did the 1.9dci engine go? Is it in the Volvos?
Certainly the 1997 V40 I've just done a load of work on does not have an EGR valve.
But, I've no doubt later V40 and S40 models got the electronic control engine.
- Kowalski
You're right that the earlier cars didn't get common rail, the common rail engine, but after one of the facelifts they started to get it, the same was true of the Mitsubishi. I don't think they got the same power output that the Laguna got even when they got the common rail engine in any case. It seems Renault didn't want to give somebody else their technology then have to compete against it, where as PSA seems happy to do so.fastandfurryous wrote:Depending on what year S40 and V40 you're referring to, I'm not sure this is completely true, as the 1.9DCi engine is electronic control (high pressure and electronic injectors, HDi style-e) is it not? The "old" S40 and V40 (from 1996-ish onwards) had the mechanical injection 1.9TD Renault engine, similar to that fitted in Clio's, Megan's and R19's etc.Kowalski wrote:The 1.9Dci was in the old S40 and V40,p20 wrote:Where else did the 1.9dci engine go? Is it in the Volvos?
A work colleague had this happen a fairly new Discovery TD after he overfilled the engine with oil.... he got his missus and kids out and retreated to a safe distance whilst the engine slowly disintegrated.... Don't blame him either (company vehicle)
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
2001 Xantia 3.0 Exclusive
1999 Xantia 1.9TD
1997 Xantia 3.0 Exclusive
1995 XM 3.0 Exclusive Estate
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
it's ok if it's a company vehicle!
my cousin bought a brand new Clio 182 last year off the internet, he didn't like it and it had electrical problems, so he sold it for more than he bought it!
anyway, has this engine running on ever happened to a xantia, they have front handbrakes, would that help at all.
so LHM doesn't boil, thats so cool.
can't you shove an automatic into Park and hope it stops?
Nearly got choked at an auction last week when a Focus "Ran away" half way through the bidding. Couldn't see the auctioneer for nearly 10 minutes until the smoke cleared!!
Just hope the previous high bidder was not forced to still buy it afterwards!!
98 zx 1.4i temptation, wanting a xsara VTS!
53 Riley RME- 27000 miles.
Deian wrote >> can't you shove an automatic into Park and hope it stops?<<
I doubt you could get the locking pin to engage if the car was moving at any sort of speed, and if you did, it would snap off rather than stop the car or the engine..
Your only sensible option, is to select neutral, brake to a standstill, and exit the car asap!!
James. (Nr M67 East of Manchester).
Dark Blue ZX 1.9D Auto 1994 'L' 5 dr (modified) Aura. 98K miles used daily. Ave mpg 40
Wedgewood Blue 75 CTD auto Connoissaur. 2002. 144k. used daily. ave mpg 40 ish.
Never heard of a Citroen turbo diesel run-away. But it might of course happen as pr statistics some day ...
It has nothing to do with build quality - or engine oil quality. Its just statistics - nothing can be made 100% error free.
BTW : previously it was a wellknown problem here in DK with n/a diesel engines run-away. Because cars are so expensive here that we kept on driving in cars screaming for the scrapyard. And the engines were untouched because of service costs. Had a colleague who had a VW Golf I diesel which just barely could keep itself coasting when near home or work - because then the engine & oil was so warm it could escape the piston rings into the combustion. He had to stop it by braking the car while in gear. The engine oil was never replaced - but rather consumed ...
Anders (DK) - '90 BX16Image
Rather as Anders says old worn engines can develop lives of their own. Some years ago when Cummins produced a two stroke diesel it was a common problem for the engine to bounce against a compression just enough for it to run up backwards. The wear in the governor was just enough for the fuel rack to leak fuel in and once away it would then overide the stop lever and governor and allow the revs to steadily rise to destruction.
Standing alongside a 2 litre diesel is bad enough but I dare you stand alongside a 6 cylinder 6 litre version once it gets going
The answer if you were fast enough was to stuff your coat in the intake but most people just did the one minute mile across the yard.
Citroens are dedicated to those who take a big bite - and just keep on chewing!
