Xantia 1.9td clutch cable easy to change?
- My Cars: C5:Hatch & an Esatate. Real cruisemobiles.
Fir others about to attempt this:Ive done a few and found it easier to bend the metal bit that fouls the pedal bolt. Saves cutting then.Still a pig to get to without pulling out the drivers seat (10mins).Overall job much easier with two people.Make sure you get the RIGHT replacement cable too!
XantiaTD's(all gone). BXGTi, sold (sob). C5 2.2Hdi SE Exc Hatch. C5 2.2 Estate auto. Xsara Hdi estate. Yam YZF750, Zoom. GSX-S750, mmm.
i agree with that, first time i did one i really struggled, then found it was the wrong cable. made me swear it didMonkeyfeet wrote:Fir others about to attempt this:Ive done a few and found it easier to bend the metal bit that fouls the pedal bolt. Saves cutting then.Still a pig to get to without pulling out the drivers seat (10mins).Overall job much easier with two people.Make sure you get the RIGHT replacement cable too!
does get easier after the first time, i now use a dab of grease on the new plastic clip and work the pin a little to loosen it before fitting, i dont take the seat out and the last one took about 40mins (first one 2 hours +, then wrong cable)
