I'd agree with what Mandrake says, regarding the flat accumulator sphere.deian wrote:Hi, I've got a 98 2.1TD Xantia (Hydractive II), now I was 'excercising' the suspension... putting it up, then down, then back to the middle, but upon going from bottom to the middle i heard a squeeling/whinning noise (me thinks not a belt) coming from what I think to be the hydraulic pump. Is this a bad sign?
Also, how is it suposed to go up/down... in little steps (as it clicks away) quite slow too, reaching most of the way then finishing off the last 1/4 of the movement to the top after a few seconds? or is suposed to be smooth and pretty quick?
So any advice or experiences from anyone who knows?
(It handles amazingly for a big heavy car, really gave it some stick seeing as the roads have dried out, I think a set of good tyres would benefit a lot too, as the suspension leaves a lot of work for the tyres to cope with)
Thanks people.
My Xantia has a flat accumulator, and behaves exactly as you describe. Frequent ticking while rising, front going up in 'stages', pump squealing while it happens...
I'm not too worried at the moment, because it's not currently in use, however it will soon be, so obviously that'll be replaced as a matter of urgency. The front strut tops are worrying me more actually....
