Got a problem with my brothers 306 '94 td. The heater blower motor and rear demister does not turn on. I have searched for the problem on the forum, and changed the barrel / switch - but it still won't work. It had worked intermititantly, but when it stops working does so for ages.
There also seems to be a clicking from the relays - again intermitant, but getting worse. Not sure whats causing it & whether or not its related. I have tried changing the relays, checked fuses - same. Any ideas?
306 blower motor and other electrics
shezads
Found my Alfa at Last!
04 156 2.4 JTD SW Veloce (Pics coming soon)
In the family:
W 306 HDI
M 306 TD
In the family:
W 306 HDI
M 306 TD
Clogzz
- x 40
Check for 12 Volts at the motor plug.
The current for the blower motor is too high for the ignition switch.
There's a modification with relay to supply the fan motor:
http://www.frenchcarforum.co.uk/forum/v ... hp?t=17322
Linchpin
pugxpert
