I suspect my 406 may have something akin to this at the mo. The brakes have just started to gently sqeak - completely out of the blue. So I assume it's just wear.Kowalski wrote:I've heard of one method for detecting worn brake pads its a metal tab that sticks up inside the friction material. When this tab contacts the brake disc it makes a screechy type of noise, the same sort of noise your pads make when they get down to the metal backing. I think this may have been an american idea.
I'm not really a fan of the warning light idea. I had a binding pad on the 405, but the dumb pad, not the live pad - which is the one with the wire. The damb pad wore right down to the metal with no warning at all. Luckily I knew the sound of metal to metal as soon as I heard it and replaced the pads straight away, but I wonder how many non-mechanical people would assume that no light = no problem. Having said that, these are the kind of people who would carry on driving even when their braking is virtually non-existent, so maybe some kind of warning is better than none.
