Yes that's a good idea, reference information, and an opportunity to warm up properly, and have a brew.BonceChops wrote:You could always take a couple of digital photo's along the way if your not sure. Then you can nip inside for a brew and a warm while you study the pictures.
Replacing BRAKE Pads
Good Idea
- Kowalski
- My Cars: Ex 05 C5 2.0 HDI Exclusive 145k
Ex 97 Xantia 1.9TD SX 144k
Ex 94 Xantia Dimension 1.9TD 199k
Re: How To Fit Pads Correctly
Was this propaganda from the camp that wants all mechanics to need certification? Personally, I can strip and reassemble brakes safely.ACTIVE8 wrote:Interesting story on this subject in this months Car Mechanics magazine.
The story which is in the trade tricks section is about how someone had fitted a set of pads for a friend. The thing is the brakes were still noisy after the work, and the car visited the garage which is the source of the trade tricks section.
This was where it was apparent that the source of the noise, with the wheel off, and there is a photograph to prove it, was the brakes that this "friend" had worked on. This "friend" had fitted a pad round the wrong way.
I remember a program (Watchdog perhaps) where they took cars to various garages to get new brake discs and pads fitted and many of the garages didn't do a completely satisfactory job (e.g. not connecting sensor wires, not replacing split pins etc).
The worst situation I could think of would be being compelled to take your car somewhere where the mechanics were less than competent. Imagine if they didn't do a proper job, you could see that the job wasn't done properly but couldn't yourself sort it out, you had to take the car back to the garage.
Agree with bxbodger here!!bxbodger wrote:There's only one way to check for pad wear- take the wheel off and look!!
If there's only a couple of millimeters or so of pad material left then change them.
Don't rely on sensors or warning lights- the pads may have been replaced in the past and the wires not reconnected or just cut off because of spurious signals.
Taking the wheels off and having a quick look at the pads should be part of your 6 monthly maintainance checks, especially if you do high mileage....and is the only way to tell for sure.
I never rely on waiting for the dashboard wear light, and I have never seen one come on in any car I own - except when it shouldn't due to wires rubbing through and shorting to metal objects!
If the pad material is getting thin, replace them...not only are good brake pads a safety issue, but if you leave them until they're worn right down and screeching, they're usually eating up your discs as well, doing permanent and unnecessary damage to them.
When they get very thin brake pads also seem to start disintegrating - cracks and other nasties can form in the pad surface, I've even seen whole chunks of pad surfuce delalminate and fall off.
Citroen quote the following figures for new pad thickness and minimum pad thickness for the Xantia (not counting the backing plate):
266mm front discs - new pad 11mm, minimum 2mm
283mm front discs - new pad 12mm, minimum 3mm
saloon rear discs - new pad 11.4mm, minimum 2mm
estate rear discs - new pad 12mm, minimum 2mm
So there you have it, from the horses mouth. If they're under 2 or 3mm replace them.
Regards,
Simon
Simon
1977 G Special 1129cc LHD
1978 CX 2400
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
I had the pads out of my 2.1 for the first time this weekend. What's odd is that there aren't any wear wires or even holes in the pads for them to go on.
The pads are lucas so it's not a case of cheap pads.
98 Xantia 2.1TD Estate 140,000mls
01 Xsara HDI, 130,000mls
97 Xantia TD, 240,000mls (died in france)
In my experience when brake pads wear down to the brass rivets holding them in place the brakes always make a very loud grinding noise.. Ignore it your peril... oeerr..
James. (Nr M67 East of Manchester).
Dark Blue ZX 1.9D Auto 1994 'L' 5 dr (modified) Aura. 98K miles used daily. Ave mpg 40
Wedgewood Blue 75 CTD auto Connoissaur. 2002. 144k. used daily. ave mpg 40 ish.
NO !Kowalski wrote:Was this propaganda from the camp that wants all mechanics to need certification?
It was just pertinent information to do with the thread.
The pads (Teves) I got from europarts last month came with holes and a full complement of wires and connectors!!Two different types even!!
Pity I haven't got any wires left under the arch to connect them too......
i'd say its a grinding noise, but not that loud and only if braking down an inline.
As to doing it in this weather - its either i die of the brakes failing or the cold with how long it will take me to do it.
Like the idea of a digi camera.
Wondering though with what your 're mainly saying is whether to get the garage to do em'. Least i can blame them then.
Any idea of what the cost range SHOULD be, if i provide the part?
_________________________
Xantia TDS, LX (1995)
Same here, the pads I got for mine (mintex) came with nice new wires of the correct lengths and a mounting hole on both sides of each pad.bxbodger wrote:The pads (Teves) I got from europarts last month came with holes and a full complement of wires and connectors!!Two different types even!!
So much for lucas then.... (I've never been a fan of lucas pads)
Regards,
Simon
Simon
1978 CX 2400
1978 CX 2400
