I had this problem on mine and there is no replacement for that pipe, a new ram was the only solution.
They cost about £200 from Citroen, if you get it on the standard delivery and about £100 to fit at a decent independent.
Activa Ram - Low pressure LHM leak - which sealant
Pipe
Hi KevMayer
O.K. if it's the pipe that's leaking only, and not the ram. Then it should be possible to have a hose made up by a specialist.
I have previously had hoses made up by the company listed in the links below, and can recommend them.
They can make up any hose, and fitting the customer requires.
It should also be cheaper than going to Citroen for a complete ram.
www.pirtek.co.uk
http://www.pirtek.co.uk/site/Dynamic/te ... =1&page=20
www.pirtek.co.uk
