Never bothered to look or find out - but from reading Haynes it looked unusual as does the oil cooler and BX seemed to only have 1 on most so i have always thought of them as an extra - particularily as the second one doesn't seem to be needed.
I've always wondered what this one has towed as it would seem to have led a sheltered life but the clutch seemed to have been changed before we got it at 53,000.
zx td 94 cooling fans not working (twin cooling fans)
oldnail,
gsf may charge £10 less but i dont have a GSF nearby and needed one of these switches quikly.
getting it for £18 meant i could change it same day. 8)
I am happy to pay an extra £10 to have peace of mind, especially as the car is used every day in stop - start traffic.
£10 would have represented only a small fraction of the cost of a new head gasket which may be needed if the car over-heated.....
Zxtd Aura converted from 1.8i Petrol - Lowered, 20psi boost extra fuel - weeeeeee!
MK2 Cortina 1600e
Honda Acty Romahome - 545cc!! - (the "beast")
MK2 Cortina 1600e
I cheated a bit here and by passed the radiator switch with a manual one on the dash until the replacment arrived.Only took 24hours though.If you want real piece of mind I would have a good look at the relays,mine were really badly corroded on the terminals and looked ready to give up the ghost at anytime.
yeah good point, i did check the relays and the coonections and sprayed them with wd40 and they all look pretty good....
i was thinking, i have a donor 1.9d zx with twin fans but there is only 2 pins on the fan switch, i spose this means they are only single stage fans rather than twin stage as in my td - was the switch you got from gsf the twin pin type or three pin type???????
cheers
alastair
cheers
alastair
MK2 Cortina 1600e
MK2 Cortina 1600e
