In the UK there is a distinction between remould and retread, retreaded tyres are used on tucks and often when you see what you think is a truck tyre on the side of the motorway it is in fact just the retread which has come off.zzf00l wrote: To Clarify... A retread is as stated above but is more commonly found on heavy commercial vehicles. On the other hand a 'remould' is where a tyre has the rubber ground off the tread area AND the sidewall which can then be more easily inspected for suitability for further use and if suitable can then be remoulded.....It can be said that this is prefferable to a new tyre because the 'carcass' which is being re-used has already proved that it is 'proven' as opposed to a new tyre which is 'unproven'.
Retread is the American English equivilent of remould, I think Bernie meant "remould" but used "retread" instead, hence me using the wrong word.
I stand by what I said about remoulds though. If you're making remoulded tyres you are getting a hold of a waste product and attempting to make it into a new product. The tyres you start off with aren't uniform, they'll all be worn differently and potentially damaged. You've got to convert them into some sort of uniform base (by grinding off the rubber) when they're not all of identical constuction and material. Then you've got to get them to go into the mould correctly and sit in the right place and if you get it right you've made a usable tyre. I've seen some new tyres with a lot of lead on the wheel rim, its pretty uncommon with new tyres but with remoulds more often than not they need a massive amount of lead, i.e. the tolerances they're made to aren't particularly good. There is also the question of how well the new rubber sticks to the old and whether or not the inspection spotted any damage that may have been present (can they spot all internal delamination, corrosion of the steel and metal fatigure?)
With the quality control on new tyres now (my new tyres took very little weight to balance them) I'd prefer new tyres from a decent manufacturer, even if they are unproven. The "proven" carcass in a remould may have been "proven" to be bad
