Xantia diesel. Over reving for the first 3-4 mins.
Bosch may have the name written on it - and is generally noblier on top with a unit with hoses going to it on the top. Roto-diesel has the cold start cable going to the front and a small switch unit in a rubber bellows (probably split) on the radiator side. Bosch has the cable going to the back (engine side)
jeremy
I removed my 'damper' some time ago and found it drives much better (I am quite capable of driving smoothly thank you very much)Kowalski wrote:I blamed my damper for a sticking accelarator and took it off but then the accelarator kept sticking. It turned out that the plastic liner in the cable was worn through in places and that the cable was frayed too. I still haven't put the damper back on, I probably shouldPeter.N. wrote:Those dampers dont generally work after a few k miles, I would try disconnecting it, you wont notice much difference, except it might cure the problem! It doesn't act as a return spring, there is a seperate one round the throttle cable, its just to damp sudden movement, to make acceleration smoother.
Sutton Coldfield, West Mids
Xantia V6 Exclusive (2000
Xantia 1.9TD SX (2000)
Previously owned
Xantia V6 Exclusive (97)
XM V6 Exclusive (95)
AX 1.4
Previously owned
AX 1.4
- fastandfurryous
- Location: On the road, travelling at high speed. Meep Meep.
- x 4
