Hi Anders,AndersDK wrote:Simon -
There are no mating faces metal to metal - on any sphere mounts.
That would not work as the seal would then not be allowed to function.
The tightness of the joint relies 100% of the slightly compressed seal between the 2 metal surfaces.
I'm puzzled, I wonder if you have looked closely at them
I never said that the mating metal faces provided the pressure seal, I said that the mating metal faces can rust together and cause it to need "cracking" when undoing them. Of course the sealing is provided by the seal
If you look closely you will see that the square section seal is *slightly* thicker than the depth of groove it sits in when uncompressed eg. it stands slightly proud of of the flat metal face around it.
When you screw the sphere on, the metal face on the sphere compresses the seal slightly (by about 0.5mm) and then comes to rest on the outer metal face (shoulder) of the base it is being screwed onto.
Therefore the seal is slightly compressed and clamped in place providing the sealing, but there is also direct metal to metal contact between the outer section of the sphere face and the non-recessed outer part of the base its screwing onto.
It's this metal to metal contact that prevents you from being able crush the seal by overtightening it. If as you said there was no metal to metal contact, someone heavy handed could easily crush the seal flat by overtightening (which doesn't happen)
The correct compression of the seal is provided by the precise thickness of the seal relative to the recess depth. An overtightened sphere doesn't damage the seal, it just bites even harder on the metal to metal face and makes it more difficult to unscrew.
Regards,
Simon
