Hi All,
Some of the Citroen manuals I have specify bolt torques in units of "m.daN". Is this just newton metres ? Or something else ?
For example rollbar droplinks are quoted as "7 m.daN".
Can someone confirm the units ?
Regards,
Simon
Torque as m.daN ?
Torque as m.daN ?
Simon
1977 G Special 1129cc LHD
1978 CX 2400
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
'13 3008 1.6 HDi GripControl - x 983
da is the SI abbreviation for deca, meaning 1/10th, so m. daN is Nm / 10 (with the units reversed - they are French after all!). However, 70 Nm seems awful tight for the drop links! Maybe the French use this as it is similar to kgf m (kilogram-force meter) - they do like to use kgf rather than N (we have some French designed plants here and they quote pressures in kgf/cm² rather than bar, which always has us reaching for our calculators!) Note that kg to kgf is mutliplied by G (9.81) so kgf is not exactly analagous to N (2% different) (N is kg m / s²) - probably not enough to worry about at the figures we use, and the vaugaries of most torque wrenches.
Confused? I am
Confused? I am
Me neither !! Glad to see I'm not as stupid as I first thought when I saw these units...jeremy wrote:Don't think so.
1 lb/ft = 1.3558 Nm
1 Nm = 0.73756 lb/ft
Haynes states 32.5 lb ft for drop links (connecting links) which would be 44.06 Nm
Curiously Haynes also quotes kgf m - being 4.5
I haven't a clue!
jeremy
Sorry I should have been more precise. The early model droplinks with the smaller bolts are quoted as "4 m.daN" and the later model ones are 7. Perhaps they are kgf m then ? Or perhaps they are Nm / 10 as Richard suggests ?
Here are some other figures for front suspension from the same page:
Strut top shaft centre nut - 6.5 m.daN
Strut top to body mounting bolts - 2.5 m.daN
Lower balljoint nut - 4.5 m.daN
Stub axle nut - 32 m.daN
Lower balljoint into the swivel housing - 25 m.daN
Perhaps somebody can work out the units from that...
Regards,
Simon
Simon
1978 CX 2400
1978 CX 2400
Simon,
I found this on a web site:
"6) While observing tightening sequence (step 7 removal) -torque bolts to
5 m.daN (36.25lbs ft) torque nuts to 1.5 m.daN (10.88lbs ft)
7) While observing tightening sequence, one bolt at a time completely
loosen and retighten to 2 mdaN (14.50lbs ft) then turn bolt an additional 180% using the marked socket as reference."
Therefore 1 m.daN = 7.25 lbs.ft = 9.83 Nm (using Jeremy's figures)
Richard
Richard
1998 Xantia 1.9TD Estate (Sold - replaced with Skoda Octavia (sorry))
