Problems with power steering on the zx again! I have prung a leak under the pump (not thr ram this time!). All the fluid drained after a run yesterday (can see it streaming from somewhere around the pump). But, when i filled it up and left the car running (with loading the pump on full lock) No leak?
Yet today after a run to work the leak reappeared?
My puzzle is is there somewhere on the pump body itself that can cause a leak or should i be concentrating on a hose problem? It was a little too wet to get right under the car yesterday so couldn't see. Also as it didn't leak at home i had no time to look when i got to work.
Any insight people may have to these pumps would be useful.
Many thanks, Mark
