hi everybody - im new hear!
does anybody know the standard boost for a 1994 1.9 xudt engine, i have found two different figures for it. Also has anybody turned their boost up? if so what to? and how far can you go before it goes bang?
ztd td boost pressure?
Zxtd Aura converted from 1.8i Petrol - Lowered, 20psi boost extra fuel - weeeeeee!
MK2 Cortina 1600e
Honda Acty Romahome - 545cc!! - (the "beast")
MK2 Cortina 1600e
My Xantia 1.9 TurboD with Bosch pump, KKK K14 turbo and ECU control has a standard boost of 0.8 bar.
I found this out one day when I purchased a boost gauge and tested my boost. It was 0.8 bar max. Haynes said 1 bar so I thought I had a problem of lack of boost. I contacted Citroen and their technical support confirmed that 0.8 bar was standard for my ECU controlled car.
I had it increased to 1.1 bar, by Allard Diesel Sport, which is about 16 psi.
I am told by my Local Citroen man that Xantia prior to ECU control were set at 1 bar. Haynes, for the Xantia, shows 1 bar so thats probably where they got it from.
Yours is the same engine- pre ECU so could be 1 bar standard.
Please bare in mind. I am no expert by any means. I just pick things up as life passes by.
Cheers, Kev
Cheers, Kev
Cheers, Kev
zx boost
hi thanks for your replies...
i too found 0.9 bar but the other figure i found was 1.3 bar (so thats about 18psi??) i think that is probably wrong though
cheers,
alastair
p.s great forum ive learnt loads reading through the many zx posts!!
cheers,
alastair
MK2 Cortina 1600e
MK2 Cortina 1600e
- My Cars: Citroens since 1990, BX Diesel, GTI, TZD with 1.9 TD running extra boost before it was fashionable!, ZX Volcane TD, S2 Xantia break 1.9TD, Xantia HDI 110, currently zipping about in a C2 Diesel. C2 died from the dreaded worm, C3 Picasso HDI Exclusive, the adventure continues.
- x 31
I think standard boost for the 1.9 is around 13PSI, I increased mine to 15PSI and its definitely quicker than standard, some guys are running 18-20, I would but Im scared
Stewart
Stewart
zx boost
yeah im running 20psi peak (foot on floor in 4th going up steep hill) but generally it pulls about 18-19psi and indeed it does go like s**t of a shovel. I was concerned about it blowing up (head or conrod) but its been fine for about 6 months and it had a damn good thrashing over xmas when my mates came back from uni so i am fairly confident the engine will survive. - if it was going to explode i rekon it would have over the holiday becuase i pushed it pissing all over my mates focus.
I think you would have a job on damaging these engines provided they are given good anti-freeze (to prevent them from corroding the head gasket) and a strong cooling system generally because the heads are very sensitive to temeperature changes. Mine should be okay because ive flushed it and fitted a new rad after i damaged it fitting a new clutch.
On the subject of con-rod snapping these blocks were used for the hdi's i heard so they must be tough..... - even though mine is pushing out more power than the lower spec hdi engines (arnt they around the 110brake mark?)
cheers
alastair
cheers
alastair
MK2 Cortina 1600e
MK2 Cortina 1600e
- x 31
Stewart
Stewart
