Car is a 1998 Xantia turbo diesel estateNeed to run 2 x 8 gauge cables into the passenger footwell area. I have had a quick look but cannot find any grommets etc.
Need to run cables for Hifi amp that will sit under passenger seat.
Could run single cable if access is terrible.
where to run 2 cables from battery through to cabin??
- My Cars: Currently:
In the past: 3, CX td Safaris and about 7, XM td estates. Lovely cars. - x 1204
You could try following the main loom to see where it goes through the bulkhead, but you may find that there is a connector that takes it through. You could possibly take a feed from the cigaratte lighter, thats usually rated at around 20 amps, but if you are really trying to deafen yourself it might not be enough.
