electrical connection for fuel heater on xantia
mike_zr7
Unread post by mike_zr7 »
I have just bought a stanadyne fuel heater, which I hope to fit in my 96 xantia turbo-diesel. Can anyone tell me the eaiest way to connect to the 12v electrics. I only want power when the ignition is switched on. I noticed there is a spare fuse in the engine compartment fuse box, but I dont know if this is controlled by the ignition switch, and if it is how to connect the wiring to this fuse.
1996 Xantia 1.9TD 78.000 miles, not yet run in
mike_zr7
Come on guys, someone must have connected some type of electrical accessory to a xantia???
mike_zr7
I have found that the thinner of the two wires connected to the coil is live only when the engine is running. So this is the wire I should connect to the fuel heater relay. Hope this is of some help to someone doing a similar job in the future.
