Xantia dashboard lights
Nomad
Unread post by Nomad »
Hi
The bulb that tells me that my head lamps or on, on the dashboard does not seem to be working, the side light bulb is working fine.
So the question is what bulb does it take, and while i am at it i might aswel change all the bulbs for the dashboard (only the intrument panel) so how many is there so i can buy them all first.
I have to also change the bulb for the heater control slider panel is this the same bulb as the dashboard?
Also how easy of a job is it to replace these bulbs, any tips i should know about before starting.
Thanks in advance
Tony
Xantia 1.8i 8v Presige 1995 Left Hand Drive, 5 door hatchback
johnway
Headlamps On Warning Bulb
Unread post by johnway »
Hello,
My Xantia has the same problem, but I have fix.........give the dash top a good thump with the edge of your fist above the light when your headlamps are on. You may find, as I have, that the dash light will come back on. This "cure" also works for other Xantia dash bulbs!! Good Luck.
John.
My chariots : 2002 Pug 406 110 HDI Executive Estate 138K
1995 Citroen AX 1.0 Debut 26K
I Blame it all on my Dad!! (Sadly had to give up driving & his 2nd BX) but Mum still has a C1.
Nomad
Ok Will Do :D
Nomad
Ok the above method did not work, so anymore advice on this matter would be much appreciated :)
Tony
dnsey
x 19
Unread post by dnsey »
If you replace the lamps, it's worth doing the lot.
You might consider using LED replacements, then it's done for life.
tonyb1
Unread post by tonyb1 »
Oh yes, I have to thump mine at least twice a year, never fails :lol:
Xantia 1.9 TD LX 1994 - 152,000 miles and running, strange vibrations
fastandfurryous
x 4
Also known as "emergency repair procedure No. 1" :D
If you go into your local motor factors, they will be able to show you a selection of dashboard lams, and should be able to tell you which one fits the Xantia.
This is not a signature.
