Is it quite safe to have the Xantia front on ramps and then set it to minimum height and then lay underneath to do a bit of greasing and inspection, and similarly the rear aswell, without the fear of being crushed.
Ive decided to have a bit more of a hands on approach with the car and have a scout about, ive also bought a 275piece tool box, dont know what 270 of them are but they look pretty and very clean
Regards
Safety First.....
- x 1431
Mandrake
- x 694
Re: Safety First.....
If you mean drive on steel ramps, then yes its safe provided there is enough room under the area you're working on even with the suspension set to right down - it can't go any lower than right down, so you won't get squashed.mezuk04 wrote:Is it quite safe to have the Xantia front on ramps and then set it to minimum height and then lay underneath to do a bit of greasing and inspection, and similarly the rear aswell, without the fear of being crushed.
Regards
Remember to block the wheels at the other end of the car as well, and for safety I always lie under the end of the car between the ramps, rather than lying in from the side - so even if the car did somehow roll off the ramps it is likely to roll past without touching you, rather than one of the wheels running over your stomach.
Regards,
Simon
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
1978 CX 2400
paulbx
handbrake
Note also the handbrake operates on the Front wheels Not the usual rear!
Always choc the wheels that are on the ground, you may notice that the wheels may setlle on them a bit as suspension relaxes slightly.
There are on this site lots of good tips on stopping the ramps slipping - like putting carpet underneath
Broomie(paulB) Xantia Hdi 90 estate
