xantia front suspension
citroen charlie
Unread post by citroen charlie »
Hi
Having replaced the rear spheres on my 2.1 td the ride is great at the back but now is harsh on the front drivers side. I am assuming this sphere now needs replaced, is this a straight forward job? Grateful for any advice or any tips/pitfalls
thanks
mezuk04
Unread post by mezuk04 »
Their is a lot of mention on here about replacing both spheres at either end, so if your thinking of replacing the front drivers side then I do believe people will inform you that its safe/good practice to change both front spheres
Volkswagen Golf 59' 1.6TD S :(
Mads
Unread post by Mads »
Front end sphere are very easy to change compared to the back end ones 8) , so if you survived those, you will have no trouble at all with the front end spheres. Be advised to change the spheres in pairs, i.e. change both front end spheres ones you are at it so both sides will have the same suspensione characteristics.
Mads
C3 1.4HDi, 2003, 85000km
Xantia 2.0 16v Estate, 1997, 195000km
