Cheers Alan, but unfortunately it isn't quite that simple on mine. The tower is enclosed on all sides except for a couple of finger holes (and I mean one finger only). It seems to be tightened into a captive nut beneath/within the tower.alan s wrote:If it's the same as a BX (I know the Mi16 and BX are the same) you get access to it through the tower it's mounted in from the engine side and working from over the mudguard looking back towards yourself (if that makes sense) and you need an openended spanner to get onto it.
Alan S
I only undid the top mount tonight (too cold and damp to try anything much more adventurous). I think on Saturday I'll remove the bolt from the bottom mount too, so the right hand end of the engine can drop properly, instead of rocking forwards towards the radiator. Maybe then I can get a chisel to it, and form a flat to get it turning.
In a new twist though - and after reading an old post on Aussie-frogs by you Alan - I decided to check the exhaust, and make sure that wasn't restricting movement, or seized at the front joint. Everything at the joint appearsd okay, but what I found was a fracture just forward of the joint immediately beneath the handbrake. The break is all down the right side of the pipe. Now I'm starting to believe even more that the engine is moving too much in its mounts. Admittedly the pipe is looking a bit rough, but the break isn't where you would normally expect it, near any joints/welds. I should point out that I uprated the bolts in my front mount some time ago, when I fitted this pipe, and compressed the springs more than usual to stop the pipe blowing at the front joint, so the joint is tighter than normal anyway.
Edit - The mount I have is like this one http://cgi.ebay.co.uk/PEUGEOT-205-306-3 ... dZViewItem
The bracket I have is NOT like this one http://cgi.ebay.co.uk/peugeot-405-alloy ... dZViewItem. The left hand (chassis) end of mine is completely straight, and shorter.
Sorry to use eBay pics, but couldn't find any others on net this quickly.
