I would like to change the gearbox oil on my ZX-TD.I have purchased the correct TOTAL oil from GSF.
The question is which NUT does what ? I read a few posts on the subject and a few warn of the 5TH GEAR NUT this must not be removed ?
I read the HAYNES Manaul and its looks like they are talking about a totaly differnt box ?
After removing the Wheel and and Inner Plastic wing,i have a a view of the gearbox.The bit the faces me has a small 13mm bolt underneath and a 19mm bolt at the top both have copper washers on.
Is the big bolt the Filler/Lever hole and the small bolt the drain plug ?
Wheres the scarey 5th gear nut ?
Many Thanks
ZX Gearbox Drain/Filler Plug HELP
