ZX 1.9D Sunroof leak
Does anyone know where the leak off pipes from the ZX sunroof escape to?
im sure they will br simaler to BXs rears come out in behind the rear lamp units, fronts go down inside the A pilers and you gain access to them from in the car behind the trim panel beside front foot wells,once you have found all 4 open roof fully,close sun blind,and with an air line blow up the drain tubes which will unblock the drain holles in the gully on the top of the head linning
regards malcolm
regards malcolm
- fastandfurryous
- Location: On the road, travelling at high speed. Meep Meep.
- x 4
Actually, every blocked drain I've ever experienced (which is a fair few, on a variety of cars) has been due to road wash / mud thrown up into the ends of the drain tubes, as they often do terminate in the wheelarches. I usually use a length of 0.8mm welding wire poked down from the sunroof drain tubes, if only to locate where the drains are in the wheelarch.
