brakes
casperdog2
brakes
Unread post by casperdog2 »
My car has failed the mot because under condition of service brake system they have wrote n/s/f/disc inbalance, the discs are nearly new and there is very little wear, could someone enlighten me as a am a bit perplexed.
cheers
97 xantia
oilyspanner
Unread post by oilyspanner »
Its quite likely to be a damaged handbrake cable, these work on the front wheels and are bent when the steering is turned, the outer cable can snap and cause the brake to become ineffective, whip the front wheels off and look at the cables, the are quite easy to replace and not expensive.
Stewart
x 94
Unread post by citronut »
you might find its air in one caliper,as a partly siezed cable will cause the brake/s to binde,in which case the MOT tester should have picked up on it
regards malcolm
