I've got a Xsara 1.6VTR S Reg and the windows (side and sunroof) aren't operating. Checked the fuse and it's ok.
Any suggestions greatly appreciated.
Xsara Electric Window Problem
meeper
I'm a bit new to this, but as no one else has responded I'll have a go.
I don't know of the instant fix for this, but having just had to work out the wiring for the elec. windows on my Xantia I would suggest a haynes manual and multimeter would be a good starting point. Using the wiring diagrams in the back of the manual and testing to see if things are as they should be you have a chance of working out where the fault is. You'll need to take the inside door trim pannel off to get at the electric window switches and control box. The various plugs and connectors have very small numbers on them that should match back to the wiring diagrams.
Good luck,
Mark.
Good luck,
Mark.
Stuart McB
