Current 1.9 td has thrown a piston ring, hence easier (and half the cost of rebore/headwork) to swap whole engine. Have found a pug xud9te in local scrapper.
Problem is that it has a keypad immobilsed pump - but keypad has been knackered by some numpty.
Anyone know how to programme the pump ? seeing as my zx not got immobilsed pump. Or try and source a keypad ? must be some way round it....
Need to get sorted ASAP as driving round in (borrowed) Sport Ka [:I] for last month or so. Need my trusty zx back asap
TIA
Engine Swap pug 306 into ZX
Apparently they have got the code, hence idea of sourcing another keypad. Thought this may be easier than swapping pumps - having said that, my wiring loom prob not got electricery connections anyway....would have to cobble something together
Is the keypad matched/paired to the pump or would any do from cit/pug ?
Pump would need setting up to suit 'new' engine once swapped - mine adjusted, along with boost on 'old' engine.....assume have to do this regardless.
cheers
cheers
- fastandfurryous
- Location: On the road, travelling at high speed. Meep Meep.
- x 4
And with the engine out, and the cambelt off, a pump change is under 10 minutes work. My money would be on changing the pump for one that you know. To time the pump properly needs a cheapo DTI (£10 from ebay) and about another 10 minutes work. Far better to rely on a fully mechanical pump rather than the risk of the imobiliser engaging when the battery goes flat at some point in the future.
Apparently not long since had cam belt, glow plugs and i think water pump. Would change belt & w. pump as a matter of course seeing as access is easy when on pallet.
Think will look at using pump that already there now know can get round immobilisor- that way i know i can get it up and running and know engine not a duffer - can alway swap pump in future (if a little harder to do in stu...)
Cheers
Cheers
