Can you solve this one?
batwad
My Cars:
Contact:
Post by batwad »
Misplaced haddock?
My Cars: Currently:
In the past: 3, CX td Safaris and about 7, XM td estates. Lovely cars.
x 1207
Post by Peter.N. »
Wire worm?
bxbodger
My Cars:
Post by bxbodger »
Its a Citroen, with the associated electrical system-it probably says on some obscure page of the handbook that its meant to do all that!!!
aengus
My Cars:
Post by aengus »
yeah, probably when the little light at the bottom of the n/s/r door goes out and the sunroof's open on tilt, wheel turned 45-degrees to port etc
ItDontGo
My Cars:
Post by ItDontGo »
The radio will only go off if there is an internal fault or wiring fault or the supply voltage drops too low. So that is either a short circuit somewhere, which would probably set the car alight if it was that bad, or the supply from the battery is too low. That could be all kinds from corroded terminals to lack of fluid in the battery but I'm going to go for an alternator fault. I reckon, seems how there were no warning lights, that the field supply to the alternator has failed. Still I suppose it could be anything from that small description of a general electrical fault.
NiSk
My Cars:
Post by NiSk »
How about a blown ignition warning light? or one with dodgy connections . . . ?
//NiSk
wrinklet1
My Cars:
Post by wrinklet1 »
Right, here goes......
The fault was caused by the live supply to the alternator breaking where it connected to the alternator. Therefore, the alternator wasn't working except sending just enough charge out to make the warning light not to light up. The car was running from battery power only. This caused the system to go haywire and reverse its polarity and the radio go off, ABS light to light up and rev counter needle to jump when indicating......
Paul
bbrucez
My Cars:
Post by bbrucez »
Thanks Paul,
I was having so many sleepless nights waiting for you to post this!
An interesting idea would be to have a separate Forum for idiosyncrasies like this.
Bruce
JohnT
My Cars:
Post by JohnT »
a bad bit of replacemet wiring? or a magnetic field from a speaker causing a problem....I cant do so doku either!
ItDontGo
My Cars:
Post by ItDontGo »
Bump!
Whats the answer wrinkley?
peter mawer
My Cars:
Post by peter mawer »
perhaps its the thingy that connects with the watchit ( or doesn't) that may be causing the problem. My next reply will be in the style of Stanley Unwin, you have been warned, cheers
stewart_c
My Cars:
Post by stewart_c »
OK wrinklet 1,
it was logical, and there was me thinking that you had just been playing about with your sonic screwdriver
wrinklet1
My Cars:
Post by wrinklet1 »
The Dilythiam crystals are 100% at least, and don't forget Andre Citroens saying....'Ya canny change the laws of physics' (Jim)
xantiaBFY
My Cars:
Post by xantiaBFY »
good one scotty...
mrbump
My Cars:
Post by mrbump »
reversed polarity. sounds a bit clever?
Post Reply
