Changing spheres- how do I get the old ones off?
1 depressurised system
Vehicle is on minimum height. Engine is not started, system is depressurised.
I can't get the bloomin sphere off! Had a go by hand. There was no way it was coming off like that. Next I tried attaching my oil filter removal tool! It's one of those metal ones that have a metal band and you turn the nut at the top to tighten it. Well all that happened was that I took some paint off the sphere whilst the band slid and some of the metal on the guide of the tool sort of fractured! How do I get these things off..[xx(]
EDIT, I've also tried doing as suggested on here and repressurised the system , put the vehicle on max height, switched it off and tried again but to no avail.
If your filter tool's a decent one it should work.
Tighten it very firmly with a spanner, and fit a length of tubing to give it more leverage.
Spheres can be <i>very</i> tight - you might need to lie down and push the tubing with your feet, but be very careful that the car's adequately supported[:0]
- My Cars: Current:
Volvo V60 D4 180
Previous:
BX16RS (two of),
BX19TZI,
Xantia 2.0i saloon,
Xantia 2.0 Exclusive CT turbo Break,
Peugeot 807 2.0 HDi 110,
Renault Grand Scenic, 2.0 diesel (150bhp)
C5 X7 2.0 HDi 160 which put me off French cars possibly forever - x 16
or give the filter tool a sharp tap with a 4-pound hammer in the right direction - to shock the sphere loose (assuming you've got enough room to take a small swing at it). Don't undo them till you've depressurised, max 1/4 turn, or it can hurt!
Be sure you've got the body supported on stands so it won't suddenly drop on you.
It's the fronts I'm doing at the moment. The darn sphere has damaged the filter tool! I'm scared to apply too much pressure as I can see the unit the sphere is attached to moving very slightly when I'm pulling as hard as I can!
Darn GSF Trafford. The unhelpful guy in there told me that he had never heard of a sphere removal tool and when I told him they advertised it on the website he checked again and said he couldn't get it!! One of the blokes in there is absolutely excellent, the rest seem to lack product knowledge.[}:)]
MAtt, i didn't mean to be offensive, it's just that so many removal tools have been mentioned over the time, that a quick search could get you in the right way[:)]
Try this one with the filter removal thingy: place a piece of rubber (for instnace a bike tyre inner rubber - forgot the name of it) between the sphere and the filter tool.
Also, it sometimes help to first screw the sphere before unscrewing it, helps cracking up any oxidation that may have formed.
Keep on with the news about this!
thanks 406v6 I didn't take it as offensive. I know there's a wealth of info in previous posts but sometimes it's hard to get the search function to find what you are looking for. I know I'm posting for a lot of help at the moment but my last Xantia died at a very unfortunate time. I've had to buy a new motor and am now very skint so I can't afford to have mechanics fixing the many niggles with the new Xant. I'm trying to learn to maintain the vehicle properly myself to save money and because it's something I enjoy. However, fear not I will contribute my new knowledge and skills (when I have learned them properly) to the forum and try to help others. After all that's what it's all about isn't it?
I will certainly keep everyone updated on this and my other Xantia niggles! Cheers, Matt.
