Would it be a swine to change dash bulbs?
you'll need one box from the cit dealer at least 10. Yes, disconnect AB. Dead easy to disconnect the air bag - had an orange male/female clip in connector. It's important to go slowly as trim bits - like foam behind dash panel notoriously difficult to get back in!!! Plus be careful not to overstrtch the wire loom behind the dash panel as you extract it. You can then easily take out the dash panel take it inside and change all the bulbs in the comfort of your arm chair. Essential to have some long nosed pliers - if you can, wrap some PVC tape around each point so as not to crush the bulbs.
Does anyone know the GSF part number for dash bulbs? The main dealer wanted to charge me 1.20 each for them + VAT today!!
N95932 BULB 12V 1,2W 5MM WEDGE DASHBOARD BULB 12V 1.2W CAPLESS (286) 0.35 Add
N95934 BULB 12V 5W 10MM WEDGE SIDELAMP/DASHBOARD BULB 12V 5W CAPLESS 0.35 Add
N95935 BULB 12V 3W 10MM WEDGE DASH BULB 12V BULB 12V 3W CAPLESS
