Common Problem(door) Any Solution?
Right- Xant Estate. Drivers door has just started to drop. It is at the stage where it just touches the top of the o/s/r door as it closes but otherwise closes freely. Is there any way of preventing it getting worse, and if not how far do I let it go before forking out hard cash?
Try:- Get two pieces of wood approx 2 inch by one and a half inches, about 12 inches long, and a short plank, 5 to 6 foot long.
Place one piece of wood on the door sill to protect it, then slide the plank under the door and onto the wood. (you may need to lift one side of your car if the plank is too long). Then put the other short piece of wood on top of the plank, but under the door so that the plank does not lift on the door skin.. Keep the plank as far from the door hinge as possible to give max leverage on them.
Then lift the end of the plank up carefully to lever the door upwards a little, try the door for fit after each lift untill it swings into place freely without the bottom of the door catching its sill..
When you are happy with its fit, the job is done.. This was a very common practice on Jaguars etc with worn drivers door hinges due mainly to the heavy weight of its doors, and always worked very well...
You had better examine the state of the metal around the door hinges on a modern car to make sure its capable of taking the lift first though, dont want your hinges to come off the car!!
OK thanks for advice so far. However, having looked at the other threads on the search, it is NOT the hinges, and it does NOT hit the latch on closing (latch has not been adjusted either)yet.
I'm also with Aengus. I've done the jack/wood trick on other cars successfully, but if the welds are weak it will just make things worse.
So, back to the original question- it's started but is not a problem yet,so is there any way I can stop it getting worse?
Open the door fully and carefully apply upward and downward pressure on the open end - if you can see the hinge attachment panel flex, then you have the ususl problem with insufficient weld penetration. There are a number of suggestion on fixing this on the forum, from drilling and welding to just drilling and bolting. But get it done quickly, before any more damage is done.
//NiSk
//NiSk
I know you say its not the hinges, but open the door fully & look at the pin in the centre of the hinge, both of them had come undone a little on our blue xantia, not enough to worry about but it did make the difference between shutting the door once & slaming it twice!
If you have alredy checked this then don't bite my head off - I only have one
I used to have this on my estate. All I used to do was grab the door when open about 4" and pull it up by hand. I used to do this every few months. From what I can remember the panel the hinge is welded to is quite thin guage steel and just deformed. Although I did this many times it never propagated a crack although there will be a point when this causes fatigue and it does crack. Make sure the striker pin is in line with where the hinge places the door. If this is set wrongly then as you drive the car and it flexes, the additional stresses placed on the hinge will crack it way before any manhandling you do will.
If you do leave it drooped, the striker plate will be lifting the door up constantly and the hinge panel will be flexed elastically. The flex whist driving will cause it to keep bending back and forth all the time. It will crack quicker like this! Bend it by hand once into the right position, adjust the striker (if it needs it) and keep an eye on it.
Better it be bent a few times a year than all the time driving.
JMHO
Stoo
JMHO
Stoo
The best thread on the subject is http://www.andyspares.com/discussionfor ... IC_ID=5425
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by rossnunn</i>
Sorry mate- it was late when I posted [:I]
Hinge pins on mine are Torx-headed and are as tight as they can be.
Otherwise- does pulling the door up really work on this vehicle and is it sensible: there appears to be some confusion as to whether it protects the striker or damages the weld panel further.
