New Car, Another New problem!
I must be a sucker for punishment buying these Xantias but they are strangely addictive and above all cheap (well to buy initially at least)..
There seems to be fresh, room temperature water droping from the passenger side of the underneath of my new Xantia. It looks like it's coming from the back of the engine compartment (it's kindof dropping down onto the road approximately straight below where the LHM tank is. It gets faster if the car engine is running, still drops down a bit if its not. The water is clear, defo not LHM or oil. The water is only a little bit warmer than it would be out of the cold tap! Any ideas?
The car is an 1999 Xantia 2.0 HDI SX with aircon
I don't understand, so is there a problem or not? Yes I was not best pleased to see the water. At first I thought it was probably just dripping off because it had been raining the previous day but when I realised that it was not because of that I started putting my hand under the fluid to see what it was (praying it was LHM or molton coolant!!). TBH I expected some teething problems when I bought this one because a Xantia HDI 110 SX for £1250 seemed a bit too good to be true to me!! I had a budget of £1500 and don't need the car much in August so I'm hoping to use the summer to get this baby shipshape for September when I'll probably be doing more miles in it again.
