Xantia bad vibrations
Post Reply
FEDAK
My Cars:
Post by FEDAK »
Between 65 to 80 mph my TDI has excessive vibrations that are I cannot pin point as it appears to be central. The wheels have been re-balanced and the front whishbone bushes were replaced some 6 months ago. I can't find any play on the rear wheels either (should I depressurise the hydraulics to check this?)
Any Idea's ???
Chrispy
My Cars:
Post by Chrispy »
Warped discs? Big lump of rust/ cack on a hub? Bent driveshaft? Worn wheel bearings causing slight play in the hub? It's got to be something thats rotating out of alignment to behave like that.
mezuk04
My Cars:
Post by mezuk04 »
Just learned to accept my vibrations...though there not as bad as they use to be [V]
FEDAK
My Cars:
Post by FEDAK »
New discs on the front. The steering is not really affected no big lumps of cack anywhere, bearings feel ok
Forth
My Cars:
Post by Forth »
Check for rear tyres being distorted (on the tread surface rather than sidewalls). In use that can cause vibration just as stated.
Post Reply
