Filtering used oil
Filtering used oil
Having read on here that you can run on used veg oil, A friend of mine has for an Indian takeaway and they go through about 100 litres a week, which I can get for nothing. What exactly do I need to do to filter it?
- Kowalski
- My Cars: Ex 05 C5 2.0 HDI Exclusive 145k
Ex 97 Xantia 1.9TD SX 144k
Ex 94 Xantia Dimension 1.9TD 199k
You need a pretty fine filter to get the suspended particles out, a sand filter would be ideal if a little slow. Whatever filter you use it has to filter particles down to the size that your fuel filter will capture otherwise your fuel filter will get clogged pretty quickly.
Obviously you'll have to remember to pay the duty (27.1 pence per litre + VAT).
'13 3008 1.6 HDi GripControl - x 994
www.bio-power.co.uk
tells you all about making bio diesel!
Another good site is http://www.vegetableoildiesel.co.uk/forum/index.php
If you have a lucas pump - then the pump will fail fairly soon. Unless you fit a twin tank system with the veg oil heated. You an modify seals in the pump - but this is difficult.
May be easier to swap for a bosch unit from a scrapyard - that way you can run on vegoil without serious failure.
Probably better to mix with 20 - 30 % diesel though.
There is a body of opinion that says that the seals on a BX fuel pump are so old they are likely to have perished anyway, and so will be impervious to veg oil. I know some members of this forum have had good experiences. Another school of thought says that the greater viscosity of veg oil causes Cav pumps to break their spindle. Watch this space.
O
O
- Kowalski
The TD pump would work, you'd have to blank off the enrichment pipe to avoid dirt getting in, and you'd have to calibrate (set it up so it gives the power it should without smoking) it for a non-turbo engine too. I think TD pumps are set up more conservatively off boost than the non-turbo ones.
If you change from a Bosch pump to Lucas or vice versa I think the injector pipes will be different.
About a year ago I bought some new veg oil from a shop, about 30 litres in total I think it was.. Cost about 40p a litre, and I just kept adding it straight from the can untill I ran out.. It must have been about 70-80% veg oil mix at the end but the car ran better on it performance wise, but was not quite as econimic in terms of miles per litre.. About a 10% loss I think, but the car ran well on it, and it doesn't seem to have had any adverse effects..
I just filled up localy at 91.9 a litre... [:(!] hmmmm time to go shopping again? [;)] heh heh .. [:o)] [:D] [:D]
edit.. Doh.. forgot to say a coffee filter should work ok.. [:I]
Regarding filtration of vegi oil you can always use cotton wool. A 2 litre plastic bottle, cut the bottom off, invert it with the cap off,loosly pack the cotton wool to fill one third of the bottle, suspend over clean container and let gravity and the cotton wool clean the oil. You can make as many as necessary.[:D][:D][:D]
Regards
Jon
Regards
Jon
