Greetings Chaps/Darls/
My 1990/1 1.7 TD BX (1991) has slight movement in the drivers side of the power steering Ram (deffo not T.R. Ends). The free movement is happening under the gaiter or in the Ram itself. The Ram doesn't leak but it feels slightly heavier than it should be (and always has for years).
Is there any serviceable 'bits' that could be causing this movement or is it a case of putting a known good Ram from a 1991/2 1.6 Petrol BX that I have available (will it fit??).
Thank you all for you time and input!
Gary
Play in Power S. Ram
- cornishbx16v
If it is inner track rod ends you may be interested in http://www.andyspares.com/discussionfor ... C_ID=12912.
Apparently the boots are fun to fit as well
http://www.andyspares.com/discussionfor ... C_ID=12992
Jeremy
Jeremy
