Xantia fans working overtime!
Clogzz
My Cars:
x 36
Contact:
Post by Clogzz »
My fuse box is ridged, so yours is a different arrangement.
ktaylor21662
My Cars:
Post by ktaylor21662 »
Still here! Which should I pull? F is on the left, E on the right.
Clogzz
My Cars:
x 36
Contact:
Post by Clogzz »
On mine, it was the one furthest away from the front.
Since your arrangement is different, it's a matter of experiment.
To know, pull any one out and then turn on the air conditioner...that will make the fans spin at the low speed.
If they don't...you've got the wrong fuse out.
Switch off, put back in, remove the other one, switch back on...if fans spin at the low speed, you've got it right.
Don't remove fuses while the aircon is on...it will spark.
ktaylor21662
My Cars:
Will try that. Thanks Terry.
Clogzz
My Cars:
x 36
Contact:
Post by Clogzz »
Best of luck.
ktaylor21662
My Cars:
Tried this. They are obviously are in the fan circuit. The fans don't operate with either fuse removed and the air-con switched on.
ktaylor21662
My Cars:
I'll try again tomorrow when I'm working. The engine is cold at the moment.
Post Reply
