Hope you can help with this one.
Xantia 1.9tdi R reg 5 door.
Ok, new clutch 6 months a go.
Last week, went to go into reverse, no reverse[:(!].
Rubber in the small upper gear stick linkage had perished.
Fitted a new small upper and a new long gear stick linkage, as this broke, trying to remove it, to get to the smaller broken one[:(].
I didn't renew the lower small linkage.
That's 3 linkages total
I lubbed these and cleaned the rod balls, (because the old ones were dry, sorry for the terminology[:I]).
Now the gear changing is,"sticky?, notchy?"
I also "crunch the gears", quite often, when trying to change quickly.
Would it benifit to lub the rubber ball, that sits in the cluck arm?
Any help welcome[:D].
Thank you [:)]
Sticky gear changing
Could it be that the clutch or clutch cable is badly adjusted / on its way which caused the linkage to fail? If so this would cause notchy and crunchy gear changes. I say this as my old ZX estate's clutch cable needed adjusting and I had a gear linkage go on me. Adjusted the clutch and repaired the linkage, and WD40'd the other linkages, and it was fine. Yours being a new clutch, may have "bedded in" and requires a little adjustment (ie not fully disengaging) or has been badly adjusted from the start.
hi guys
well this is another prob i have with my xant among others my gearchange is ok when the engine,s cold but when it,s hot i have the same problem can,t get it in or out of gear properly crunching in reverse somtimes when i pull up and try and get it out of gear with engine running also hard gear changing in heavy traffic so its either my clutch on the way out or just out of adjustment although the clutch peddle come,s about halfway up before it (bite,s)
pete............
pete............
