Valve clearance
Valve clearance
Afternoon all - Can annyone tell me what the correct valve clearance should be for my Xantia? (int and exh). Many thanks.
You can not adjust the valve clearances - unless you remove the cam axle. And then only by trial & error - as it never seems to get spot on first time [8D]
Because of the construction principle - modern engine's valve rocker gear very rarely needs any attention - as there are no rocker arms with adjusters.
Hi jroc, my haynes states .15mm for inlet, and .30mm for the exhaust... adjustment means checking the clearances cold, then removing the camshaft (and all that entails), removing the bucket(?) over the valve, then measuring the thickness of the shim that is already in there, then calculating the thickness of the shim that is required to achieve the correct clearance. ( This is why, when I found that my clearances were "about right", I left well alone - My apologies to those on here that do things properly... I salute you all ( I have a 93 tdsx btw)
Thanks mpr1956. There aint even a gap to get the feeler blades in! the valves have well closed up. Snap ive got a 93 sx td as well. I only bought the car for £90. It was so cheap because the owner said it needed a new head gasket - the valves could have given a false reading on a comp test (I hope so). Plus I need to get hold of a new n/s/f door as its a bodge job as its a shoddy replacement (a ill fitting green door on a blue car). But it is great fun when the turbo kicks in! Whoopee. Thanks once again.
I've done this job a couple of times on my old C15D's.
On both vans the clearances had closed up by a significant amount, changed the shims and the engine ran smoother with an improvement in MPG.
Not an easy job to do but worthwhile if done when changing the cambelt. The biggest problem was getting hold of the right size shims, dealers rarely carry them.
I have to change the cambelt annyhow (the one on the car is well shot), I bought the belt yesterday in GSF (swansea) so while im on the cambelt job I might as well do the v/c. I dont mind spending a bit on the car as it was so cheap, and the body is in good nick (apart from the n/s/f door). As you can guess im doing this for the love and not for profit. citronut dont go and curse me now by saying that, as the unit is running very, very smooth albut a small amount of clatter at idle.
